Should i swap my 7.5 out?
Jnevrotski
Law Enforcement
Philadelphia, Pennsylvania
PA - USA
Vehicle
Drive
3.0 V6
3"
255 75r16
If you cant fix it blow it up
I have a 99 Ranger xl 3.0 Vulcan flex fuel 4wd torsion bar suspension, 4r44e transmission 112" wheel base 7.5 3.73 rear abs rear only and my speed/ abs sensor is in the rear. I upgraded my leaf springs from the 2&1 to a 4&1. Opening up my rear and seeing groves in the carrier from the pinion made me realize I'm buying some time with the bearing replacement. With the price of replacing the carrier and everything, then doing the work its cheaper to just buy an axle and swap it out. This was my 1st experience and lets say 3 times was a charm with shimming the carrier. Now should i go with an 8.8? I do roofing, and remodeling with it so it gets some weight at times. Is there an axle that has the sensor in the rear? What year axle can i just throw under the truck and jook up that dont have to be modified (if any)
Ranger axle from a 4.0 truck. Bolt-in swap. 98-like 2009-ish would be for sure. 1990-2009 would work. Just look for one with 3.73 gears at a junkyard. Or if you want deeper gears look for a 98-11 donor and take both axles
*edited the years to correct information
skip the 2010-2011, they don't have the rear diff sensor and the axle shafts don't fit other Ranger housings.
do you tow much?
the 7.5 and 8.8 regular axles both use the same axle shafts and outer bearings. some 7.5 can be had with 10" drums.
Personally i dont see a reason to go with an 8.8 in your case
with that powertrain i would never worry about the 7.5 doing normal driving....
you mentioned roofing. this is not normal driving...
if you are working anywhere near the level i worked.....i would rather the explorer. or if you are actually running 3k just get a 60.
they all can handle it in the short term.
your probably currently loading and working to the point of case deflection with the 7.5 and the explorer is a magnitude stronger in handling that. the ranger 8.8 is definitely better about deflection and tearing up bearings/spiders but lives with the same shaft/bearing limitations.
This is true. Explorer 8.8 isn’t exactly a bolt-in, but it’s stronger than the Ranger 8.8 rear which only has a slightly bigger ring & pinion over the 7.5 rear. My first Ranger I replaced the 7.5 with a Ranger 8.8 because the price was right and the 8.8 had limited slip which my 7.5 was open.
That all said, the Explorer 8.8 really just needs some bits cut off the axle tube and welded back in plus shock mounts added since it was spring under axle and the shocks mounted off the spring plates instead of the axle tube. If you can weld, it’s not a terrible swap to do.
RuffStuff 8.8 31 spline simple swap kit and the hardest part it setting the axle level on stands, imo.
Put it on the stands and a jack under the pinion. Perched go directly above the old ones. I left the Explorer perches to have a flat surface for a jack or future attachments. You can use the Explorer original plates for the shock attachment if you want. (I think you have to have 2 of one side tho.)
If you decided to change gear ratios don't forget to change the front to match.
IMO, swapping to an 8.8 isn't cost effective unless upgrading to 31 spline axles.
vs what, replacing his axle with another 7.5?
Nobody in any of the yard I frequent would charge more for a 8.8 than a 7.5.
How long did it take to tear up the 7.5? In terms of miles or years.
If you've gotten a lot of years out of the 7.5 then I would just run whatever you can find that's cheap and in good shape. If your choices are a clean 7.5 with fresh brakes or a nasty 8.8 that needs brakes, for the same price, then drop the 7.5 in it.
Now if you have torn up the 7.5 in short order, a Ranger 8.8 is not a huge upgrade... an Explorer 8.8 is much better if you can weld... but honestly if you are regularly carrying enough weight to cause a problem like this, a bigger truck might be a better choice.
The problem with the 8.8 Ranger axle upgrade is the weak point isn't the ring and pinion, but the 28 spline axles. It's similar to the Dana 44 in that an upgrade to a Dana 50 keeps the weak 30 spline axles.
Swapping to an 8.8 housing gets you halfway to a decent axle. At least at that point upgrading to an 8.8 carrier and axles gets you the rest of the way I guess...:sneaky:
The only real potential problem is if you have to rebuild the brakes, some may interchange with the 7.5 if it has good brakes I don't know.
Otherwise it is the same money to buy and the same work to put in.
