professor229
From the top.....
When I bought the 2004 Ranger, the gal I bought it from said there was one quirk..... If you turn the key, and the starter does not engage (nothing happens) simply shove the gear shift lever a little harder into "P" for park..... It is apparently then that the neutral safety switch will allow you to start it. I have basically spent over 200 hours rebuilding/refurbishing this truck and this was a minor issue to me but it has happened once and I also showed my wife what to do if she turned the key and nothing happened.....
So what's the issue? I was being very careful yesterday on the maiden trip to the lake to launch my small fishing boat, and concentrating on everything to make sure I didn't miss something, when I got to "thinking" about launching this boat.... procedure of course is to back the trailer into the lake, put the vehicle in PARK, get out, stand on the tailgate, and release everything to push the boat off the trailer into the lake..... so..... would this transmission stay in park???? and if not, there you are... standing on the tailgate as the truck rolls slowly into the lake..... I didn't need that!!!! As it turned out, I backed down the ramp, put the shift lever into park and made sure it was going to stay there (revved the engine a few times to make sure it was in park), but at the same time, waited a bit to make sure... it did... I launched the boat, and parked the rig.... and repeated the same process to retrieve the boat...... but, I don't want this to be an issue...... so I looked and found the inevitable You Tube video on how to adjust the red needle that indicates that you are in park, whatever... easy to do... but.... I have some questions.... and perhaps somebody has been there, done that....
First, since the red needle is out of adjustment.... and the process to correct this appears to be quite simple, which I will do.... but would this affect the neutral safety switch as well? and correct that issue?
Second, is there a way to adjust the transmission linkage so the lever goes into park and stays there? Is this a common problem? Any ideas?
And finally.... I don't know if the previous owner used the emergency brake at all.... and if you have been working on vehicles for years, you know where this is going.... If an emergency/parking brake has not been used regularly, they are notorious for activating and working... but when it comes time to release the parking brake, it doesn't release because of corrosion etc.... so that was not an option to me... with two choices while you are blocking the fishing ramp..... and getting "looks" from other people.... waiting to launch.... I also considered shutting off the Ranger after putting it in park.... but that would mean probably a slower roll into the lake if it came out of park...
So I will adjust the red needle, but is there an adjustment to make sure this transmission is in park? My tow vehicle is a Chevy work truck and I will go back to using that until I get this situation rectified and some confidence in the Ranger....
Also, I attached a picture of my fishing rig.....and as you can see, the "bumper hitch" is too high.... but works..... but if I use this on a regular basis now, I will probably add a decent bolt on frame trailer hitch unit..... Am I going to get a surprise on this process? or is this going to be the usual four bolt process?
As always... thanks for your help...... all suggestions appreciated.... well.... most suggestions appreciated..... LOL
