that diff and the original engine crossmember where the rac and pinion steering junk was bolted added much more support than you would believe. im not an engineer either i just know that a crossmember there is very important to control the torque of the motor. some square stock of a good thickness 3/16" or so would be fine i would like to think. you could tuck it close enough to the oil pan to where it does not limit up travel for when you go to coils. plus it helps protect the oil pan from rocks or whatever.
fine by me, I'm in no hurry by any means.
I'm kinda in a hurry, but the sever lack of $$ is really holding me back lol.
I'm tempted to just say screw it, put a front shaft in and get matching gears in the 9" and go wheelin... but somethings gonna break and i don't have a tow rig yet.
What exactly do you want? the back hangers, leaves and my shackles?
what we did for the front was a little c-notch in the frame, welded in some 2"x.250 DOM and pressed the bearing into that.
well he did add that square tube at the front where the bumper should be. Is that not enough?
it is 2x4x.250.. i'm pretty sure i know what he's talking about, once i get a welder i can make something that goes in there
