Yea, "Thatguy" did that bracket assy.
Here's mine: .
I can easily adapt an AC compressor on there if I choose.
Here's mine: .
I was just saying about the a. Because he made a whole new bracket
I used a pressure line from a 1989 e150 van with a 351. With a little tweaking it worked fine. I wanted to find a way to use a Saginaw without the t bird pump. I think if I took the time to make my own adapter I could have had a normal ham can pump mounted. I need to find a full circle bracket and a pump from a junkyard. Then I could see what I could come up with. the way I did it would have been cheep if not for the new psc resi.
I used an 80's Ranger line. They have the older fitting.
Sent from my XT907 using Tapatalk 2
I'm not sure why you would need a Saginaw on a Rack and Pinion setup anyway though.
So I went to ORielly's and had them pull the following pressure lines
99 4.0L Ranger (what I have)
84 2.8L Ranger
89 351 E150 van
While the pump side for the 84 Ranger and 89 E150 looked like it might work, the steering box end did not match that of the 99 Ranger line. Any other thoughts.
