Just finished up putting a newer motor in my 1988 bronco II same 2.9 as original. I put a entire new wiring harness,clutch,transmission and switch to a manual transfer case. It turns on fine and idles fine but if I have the map plugged in it will have no throttle response at all and will die if left open throttle. I’ve tried swapping to a known good one and still does that same thing. If it’s unplugged it does run a lot better. No codes at the moment.
