were the old pads worn evenly?
did you replace just the calipers or calipers & brackets?
if just calipers did you clean & lube the slider pins?
how about the rear brakes, warm or cool?
jack the front up, engine off.
spin the wheels, too much resistance?
engine still off, hit brakes. wheel stops immediately?
release brakes, wheel releases immediately?
repeat with engine running.
if you think there is residual pressure in the lines try opening a bleeder. does the fluid run out or squirt out?
does the wheel turn easier with a bleeder open?
are the pads so tight in the brackets that they can't move?
for testing purposes you can disable the ABS by disconnecting the connector(s) at the front of the frame. follow the cables.
you mentioned rotors and hubs separately, 4WD? (shouldn't matter)
