Reverse Light Switch
If access from the top doesnt work, I'd try removing the trans cross member and let it hang. Not sure what would hit the firewall so look carefully first.
IIRC, the power should be there all the time. That switch is on the ground side. Might wanna look into it.
Cool. Thanks. I'll chase some grounds too!
Soooooooo...
One part of the mystery has been solved.
I found the connector.
Unplugged and wrapped in tape. 😡
I have the battery disconnected and it's about to thunderstorm so I didn't plug it in to test it yet.
one side of the wiring connector will be power. the other will read significant resistance because it is going thru the
bulbs then on to ground.
it should not be a dead short or open circuit/extremely high resistance.
you could measure a bulb to get an idea of what it should be close to.
