Reverse Light Switch
If access from the top doesnt work, I'd try removing the trans cross member and let it hang. Not sure what would hit the firewall so look carefully first.
IIRC, the power should be there all the time. That switch is on the ground side. Might wanna look into it.
Cool. Thanks. I'll chase some grounds too!
Soooooooo...
One part of the mystery has been solved.
I found the connector.
Unplugged and wrapped in tape. 😡
I have the battery disconnected and it's about to thunderstorm so I didn't plug it in to test it yet.
  • Reverse Light Switch
one side of the wiring connector will be power. the other will read significant resistance because it is going thru the
bulbs then on to ground.
it should not be a dead short or open circuit/extremely high resistance.
you could measure a bulb to get an idea of what it should be close to.
Resurrecting my own thread... Because I am just now getting back to this problem.
Got the old sensor out no problem.
Unplugged it and slid a 22mm gear wrench on it... Done.
Anyone have any ideas on how to get the new one in?
The gawdayum steel fuel lines are in the way.
I can fish it up into position, and get the tip to sit in the hole, but can't get it to square up against the opening and get the threads to bite.
I just need it to catch one thread and hold it then I can get the wrench back on it.
I've been fighting with it for over an hour, my hands are cramped and cold...
Go warm your hands for a while and try to de-stress. Once you get back at it with flexible hands and a clear mind, it should go in within the first 15-20 hours of struggle.
Positive reinforcement.
That's why I came here.
I knew I could count on you guys.
Well, more seriously, it does often help to take a short break from a frustrating project. Getting warm again and destressing really can be helpful. I've been there many times.
I know.
It's frustrating because now the truck is out of service until I get that switch back in.
I talked to a buddy earlier and he thinks the bevel on the OE part helped it align and seat.
I didn't buy the Motorcraft one but I didn't buy a no name white box.
"Standard Motor Products" Pretty common for replacement electrical components on RockAuto
I know.
a jewelers file on that first thread might help.
stubby wrench?
random idea, hold the switch in place with a ratcheting wrench, then twist with your fingers? or a small ignition wrench on the plastic part?
what I mean is to get creative with tools and alternate ways to access something.
edit: search "offset extension wrench" maybe a local parts retailer has one in the loaner program.
stubby wrench?
I am going to touch up the first thread a bit.
I'll try to get a pic later of the ridiculous access and location to see if anyone sees something that I'm not.
I'm going to try holding it in place with the gear wrench again and see if I can get my fingers on the connector to turn it.
So herein lies the problem.
The hole where the switch is supposed to thread in is above the rib on the side of the transmission housing directly above the green "Fuel" tags.
You can barely see it by shining a flashlight up there.
I couldn't even get a decent pic of it.
I can wedge my hand up between the fuel lines and the body.
I can get the tip of the button to line up with the hole.
By that point I can barely manipulate the switch with my fingers and can't get it to align, or square up to the opening, or the threads to bite.
And after doing that for a minute or so my hand cramps and I have to relax it, them start over.
I found another thread in another forum with a picture but the fuel lines and wiring harness were not there.
Must have been a different year.
I've spent another hour on it so far today...
Closer shot of the fuel lines.
You can see the hole in the second pics.
It's blurry because the camera kept focusing on the tip of the flashlight...
After some more looking, it seems even if I took the four bolts out of the sides of the frame rails to drop the whole crossmember assembly, it will only give me about 1.5" before it hits the crossover pipe of the exhaust!
