Rear one ton disk ?
Todd
HCT
OTOTM Winner
Solid Axle Swap
Troll land
Just got done swapping in one tons with dual piston calipers all the say around. After just having the fronts bleed and working I know I will need a larger master cylinder. I am going to get a mater from a F 350 and plume that in. As for the rear I will be running new lines and wont be running a proportioning valve and of course no metering valve as the rears are disk.
Now for the question. I don’t need to run any sort of residual check valve in the rear? I have been told by a few people that I have to, but I don’t thing so.
There reasoning is that you don’t want the pads to walk away from the disks, resulting in having to pump the brakes to get a peddle. But the front does not have a check valve and there are not problems such as this in the front. And If I where to put a check valve in line with disks wouldn’t it just keep the brakes locked, or dragging badly.
I would say if the donor vehicle has it, use it, if not, skip it.
Sounds like a cool project, so let me say:
:worthless:
