DOZER
was wondering if anyone has mated a full size bronco, rear driveshaft to a BW1350 in a B2. I already have a 8.8, just need the transfer case flange, is there such a thing as a 26sp 3" bolt pattern output flange?
sorry i guess i should have been a little more clear, im runnin an 86' b2, with 92' 4.0 & A4ld with 86' bw1350 t-case & 91' 8.8r mini spool, 4.88 d35 f. i also have a 90' fullsize bronco, i already shortend the b2 rear shaft to fit my set up and then re-drilled the 8.8 flange to fit my shaft. the fullsize shaft on my 90' is within 1 inch of b2's shaft soooo, all im lookin for is a flange that will let me bolt the full size cardan to my 1350, ive been running the smaller cardan joint now for almost a year and have found that it just does not hold up![]()
