rear drum adjuster help
That second picture looks correct.
All the photos you posted look like Ranger parts to me. Except that adjuster...
Where is the self adjuster lever... cable... guide for the side that self destructed?
I'm not sure the second pic was when I put it together and you can see how much it pushes it out and you can see the one where it's destroyed
I don't see how it's pushed out.
Like I said it looks correct. Did you have the other springs on it? Did you try to put the drum on?
I've seriously never seen any adjuster like the one you're trying to find on a Ranger.
Yeah I took the picture too close but look on the sides I had it adjusted all the way down and the drum wouldn't fit and all the springs where on
there have been times new brake parts did not quite fit. on one occasion I needed to deepen the slots on the adjuster.
Hmmm...
Park brake on or cable stuck?
Yeah so I'm lost cuz the 04 shoes and hardware fit how they should but that adjuster is just too big
I just checked my 2005 factory manual.
the short style with thru bolt is correct.
the long adjuster is for older 10"
it appears aftermarket can be either style.
Where can I find one I looked from 2000 but to 2011? To see if I could find it
it appears the adjuster bolt/screw changed a bit,I don't remember the removeable screw.
this is what Rockauto lists for a 2005, of course left & right are opposite threads
your short one looks more like a 1999 Explorer, listed in previous post.
