dashhho
I was checking out my drums today and noticed some vertical play in the axle. The drivers was quite a bit, the passenger side was less but still noticeable. I'm guessing there shouldnt be much play if any? The seal seems to be holding at this point as there is no diff oil leaking yet.
I'm looking at parts and am a little confused here. It looks like Timken/National sell a single unit bearing/seal?
https://www.rockauto.com/en/moreinfo.php?pk=221810&cc=1431252&pt=1672&jsn=980
https://www.rockauto.com/en/moreinfo.php?pk=1116817&cc=1431252&pt=1672&jsn=976
OR you can buy the bearings/seals seperately but some of the part numbers on rockauto are the same for 4wd/rwd?
https://www.rockauto.com/en/moreinfo.php?pk=1119420&cc=1431252&pt=1672
I have a 4wd 8.8 ring gear 28 spline.
Has anyone used the "Bearing & Seal Kit; Optional Axle Repair Bearing Replaces O.E. Bearing and Seal"
