Ranger Sport Honduras official build thread
my switch tried to burn my truck down when i first got my truck, it was due to the fact when the truck was brand new it went through the ice and blew bubbles for a few days in houghton lake...some damage you can not undo without replacing alot of items. hidden damage like wiring is a headache in a half
its been on a three way toggle and relays ever since.
ohh i get it now.
i think ill just buy a new switch.
thanks for the tip.
what u think about my shaft idea?
i think you should mail me your truck.:D
mmmmm.
define done:D
Here's the plan :headbang:
I'll leave the rear part of my shaft as it is
then I'll cut it and add the exdentable thing to it. :icon_welder:
I'm taking the t case rear output flange so they make a new flange that matches it to go on the front of the driveshaft.
(Yawn) Somebody wake me up when this is over-
Don't forget to take LOTSA pixs of shaft at machine shop !!
haha i cant promise pics, since i wont be there doing it.
i just want it to be done soon enough.
OK, the rear drive is finally done.
i had planned to install the 4wd trans tomorrow, but the machine shop guy came up with a great idea for making a front one without getting parts ordered from the States.
We will have to use parts of a Toyota front driveshaft, but i dont mind that.
ill update that when we get some work done.
For now, here we have the rear driveshaft building pics.
Cutting the slip yoke form the old driveshaft
part 2
point of no return, cutting my stock driveshaft
test fit
and done
dont worry, ill remove that old bearing later
now, lets make a new flange, so i can bolt this thing to the trans
drilled the flange bolt holes
welded.
the trans flange is just tackled in the back. not fully welded, dont worry.
shortening the driveshaft.
this sleeve will go between the 2 parts.
done driveshaft.
total cost: 60USD.
60 USD..... 60. ....6...0.....USA dollars....
i know thats probably a lot in the area, but dam. around here thats 500 USD atleast!
now you have to do it. congrats! now, chop apart your front end! thats the point of no return.
even here, 60 USD is really cheap.
Ill have to wait a bit for the front end tearing, since i still need brakes.
Thanks for sharing the pixs & video !! Daps to RSH-
Thanks man, repping u back.
that driveshaft looks complicated... lol.
congrats! one step closer!!!
