Ranger evaporate cannister connection wuestion
Featured Build Threads
Connecticut
On my ranger the spare tire holder rusted out and evap cannister fell dragging on ground. The wires broke on connector. Does anyone know where to get a new one and does it matter which wire goes to which side.
Wrecking yard is best bet
You can buy new
Only electrical connection would be the Vent solenoid, and its a solenoid so has no Polarity, no +/-, so as long as both wires are hooked up it will work
You can test used solenoid with 9v battery(or car battery), should "click" closed when powered
You can buy new
Thanks for reply found a connector at o Reilly standard s1752. Only difference was slot on top was offset and mine was in middle removed That spline and went right on. Only thing it was 48.00 what a ripoff
Jeeze, thats PRICEY
But if its fixed then in the long run its was just a blip on the wallet
Event Coverage
Featured Ranger Based Vehicle
