railmans build thread....
howd you pull that off? im gonna assume on a sidehill area with a tree
yup....exactly:icon_thumby:
I used some pliers to roll me a lip in the rear fender to gain that last bit of clearance I needed....
as for the front I plan to trim just a hair more off the fender, since it won't take much....
l8r, John
Wow John, I just sat here and read every page of this....:shok: I LOVE IT my friend, what a transformation!!!! :headbang:
As to your question of what happened to my transmission multiple pages back, I found out I tore several teeth off at least one gear on the main shaft and one gear on the countershaft.....they are replaceable and not very expensive, but to fix 'em I need to overhaul the whole transmission...looks like I will be down for quite some time.
I need to get 'er goin' so I can prove what she can still do!!! Gonna have 36's, cut fenders, a 4.0 clutch setup behind that high revvin' 2.8, and hopefully a front 35 when I bring 'er back out!! :headbang:
Sorry man, not trying to threadjack!!
:icon_cheers:
B2
Congrats on OTOTM John :icon_thumby: Truck is looking good
SVT
thanx Rick:icon_thumby::icon_thumby:
now ya just need to get yours back together here soon.....
l8r, John
How is the clearance on the engine crossmember? You said you're on about 5" of lift right?
with my axle moved forward 4" from stock....I just had a little trimming at the very front of the cross member to make sure the dif didn't make contact...
l8r, John
l8r, John
mine hit a little with the weak springs and no bumps....but i broke the springs in half and went to shorter stouter units as i run the roads before i went all out with bump/limit scenarios.
is it hitting hard or was this purely a preventative measure?
more preventative.....I wasn't sure how much the bumps I used would deflect....
remember, I just built a slow moving trail rig....so no whoops, or other high speed off-road stuff...
I have 3" of up-travel with my set-up before the bumps make contact....and I figured the bumps would deflect 1".....
so far it has worked for me on the 2 wheelin' trips I have been on:icon_thumby::icon_thumby:
l8r, John
l8r, John
i am watching..the tb vid was great...hope to take you up on a tb couch trip and really want the 250 ttb
you didn't tell em you already fixed everything and are ready to hit the trails again!
whenever ya ready I will be:icon_thumby:
and the D50 TTB is just taking up space out back....almost started to load it up for the scrapper today....
l8r, John
l8r, John
D50 TTB eh? :icon_twisted: :icon_idea:
No, I think I need to get that out of my head and stick with plans on a D35...
:icon_cheers:
B2
:icon_cheers:
B2
I have one of those too....
just sayin'
l8r, John
Do eet. I know where an 8 lug sterling rear is with 4.10s.
