hello i have a 1987 ford ranger i'm swapping 5.0 and t5 into, it was originally a 2.3 t5 truck, but it had no power so i sold the motor and trans to a friend, and need to know how can i use an aftermarket radiator fan to turn on when the engine needs it, or would it just make more sense to get a switch or make it run 24/7 when truck is on? also if someone knows while reading this, is there a good aftermarket solution to make it a cable not a hydro clutch, or would it be easier to make a bracket, new master, and exterior slave to make it work?
