2.3L ('83-'97) High intake temps (radiator fan shroud?)
wisepapajohn
GMRS Radio License
Memphis
TN - USA
Vehicle
Drive
2WD
2.3 (4 Cylinder)
Howdy all, my 97 2.3l is a little sluggish when cool but after idling for 5+ minutes it's a real struggle to get moving from a stop. I plugged up my OBD2 reader and noticed that my intake air temps creep up like crazy when not moving.
It's around 90° here in Memphis and the intake temp sits around 110° when moving. It'll creep up to about 120° at a red light and I've seen it jump up to 160° when idling for 5+ minutes. Coolant stays pretty consistent at 180° when moving, then 200ish at idle. I have the stock intake that draws air from the fender.
The truck has the stock (cracked) mechanical fan with no fan shroud. I'm thinking the fan is blowing the hot radiator air all over the engine bay and soaking my intake tubing with hot air. Shrouds are hard to find online and there are surprisingly few junkyard Rangers in my area, so no luck going that route. Has anybody on here made their own fan shroud? I'm debating between that and springing for an electric fan w/ shroud.
I wonder what your coolant temps are? Fan shrouds really improve the air pulled through the radiator.
They have these which would be quick to install, and better than nothing. Don't be afraid of the through the fin mounting. I used to wonder about it also, but some electric fan kits mount that way also and I had one that lasted a very long time mounted through the fins with no problems.
eBay has loads of shrouds for right around 50$ shipped, they're actual full shrouds too.. what you posted really feels more like an aesthetic piece rather than something made to actually function.
Replace the mech fan as well. It's the superior fan unless you're willing to spend big bucks on an electric one.. moves WAY more air.
that is normal. a shroud might make it worse. might help. you have to try it.
Manual transmission 2.3L rangers without A/C don't have fan shrouds, just a shield at the top to keep your fingers out of the fan...
Your experiences are similar to mine on my '97, it runs like garbage when the outside temperatures are over '90 which I have found to be intake temperature based as while I was watching the spark advance and intake temperature at the same time on the Torque app with my blue dongle thing while accelerating at low speeds with high intake temps the spark advance will go NEGATIVE, IE it has no power (not that it's a powerhouse to start with), but I found out that if I feather the clutch and run it over 3000rpm it's not near as bad... I have a plan to just bypass the temp sensor with a resistor to make it think the air temp is like 80F and let the O2 take care of the fueling but haven't gotten that far...
For the record it was 98F here today, my fan was screaming and robbing power and that's exactly what I did while yelling at all the dumbasses I was stuck behind that had electric fans and A/C that had not a care in the world and would just wait out green lights while I had my arm out the window flailing and using it as a scoop once I did get moving... I would have honked but I was usually 20 cars behind the problem because people are stupid...
Thanks all.
I should've mentioned, my Ranger does have AC and PS. The problem isn't nearly as bad when the AC is off(as you'd expect) but spent far too much time and money getting the AC up and running to roll without it.
I've been cutting the AC off when the traffic light turns green, then turning back on once I get to about 15mph. Gets me where I need to go, but I don't want to have to do that, y'know?
Coolant runs a bit low if anything. 180° while moving & seems to max out at 200° at idle. I replaced the water pump a few years ago when my timing belt snapped and there's a very good chance I never put a thermostat back in when reassembling. In my defense, it was about 15° out and I was moving across town the next day so I was in a hurry
I'll go with an ebay shroud and see if that makes any difference. Very good chance my fan clutch is seized too, so I'll add that to the list. Shame Rock Auto doesn't sell the fan/shroud.
I wonder if it'd be worth trying to insulate the intake tubing. Or getting a heat shield for the exhaust, that being unblocked definitely isn't doing me any favors
Thanks all.
That heat reflective gold tape would be a better idea for the intake tubing.. insulating it would just make your issues worse once it gets heat soaked.
Insulating the header on the other hand.. that would be adventagous.
If you have A/C that would definitely drag you down just that little bit more using up power you don't have... Having to accelerate WAY too many times in traffic over the last two days I can tell you from experience holding 2500rpm or more helps tremendously! If I use my normal driving habits of staying under 3000rpm it's a turd... but if I slipped the clutch and held the R's up a bit and stayed in a lower gear until like you said I was moving 15mph or thereabouts it was just fine...
Maybe this weekend while it's cooled off I'll figure out what resistance resistor I'd need to bypass the sensor with...
Heat-reflective tape and a new fan clutch are on the way. New fan & shroud will happen when a suitable Ranger hits the local junkyard.
Slipping the clutch at 2.5k has been a big improvement the past couple days though I can smell it burning if I'm not careful. This clutch probably should've been replaced 50k miles ago so burning a few miles off isn't the end of the world. I'll probably replace it this autumn.
I've been using the Torque app to monitor temps, haven't paid much mind to spark though. I'll throw that on my little Torque dashboard and see if that clarifies anything. I keep an old tablet in the truck connected to my OBD2 reader so I can keep an eye on temps and whatnot. I'm currently monitoring revs, intake temp, coolant temp, MAF flow, and vacuum. Anything else I should keep an eye on?
I ran my '93 four banger for a while without the shroud until I took it to an A/C place. They wouldn't even work on it until I put it back on.
My only other go to value to watch is O2 multiplier to see how crazy that's getting...
I was looking at spark one day since I was out of other ideas on why it was so doggy when hot when I noticed the low limit on spark advance being like positive 5 or something dumb then paid attention to when it was happening and that's where I've gotten so far, it's a hole in the table or just how the tables cross in unfortunate ways...
My clutch is questionable (unknown when I got it but put 90k on it since then) but I'm not sure I'd slip so much as to smell the thing, I just feather it while accelerating and hold first for longer than normal...
I'll check tomorrow on what resistor might work...
I didn't forget this time...
If I'd bet on the resistance values I would have lost my ass... it was around 110k ohm at 70F and around 21k ohm at 80F... so if you found a 20k resistor and put it across the intake temp that should be a reasonable place to be... I'll try it on Monday, don't have any resistors at home.
I'm on day 2 of the experiment with a 20k ohm resistor and it was just over 90F on my way home and no hesitation! Worth a try if it's really bugging you... I used a 1/2W resistor, folded the lead wires in half and twisted them (had to to get big enough to catch in the terminals of the connector) then just shoved the two leads across the connector and taped the lead to the crank vent hose (was on top and easy, zip tie would have been easier but I was working with what I found in the door pocket).
Once fall rolls around if I keep it that way that long I'll plug the sensor back in, if I get to thinking about it I'll zip tie a baggie over the sensor connector and the connector with resistor... I have an idea with a 3 way switch but don't know how involved I want to get...
Switch. Switch. Switch!
I have a few elephants in the room to take care of like getting the transmission in my F350 working (or buy an interim beater full size to tow and haul the camper) and swapping the front diff and tires for my '00 Explorer so the wife can do the truck pull in it again (I'm sure she's going to want to) which all happens the week after labor day!
