i need to know how to keep my passenger airbag ON while taking everything out for the full center console mod. is it just hook up both wire ends? thanks
I am interested in this as well I do my full explorer console. Do Explorers have the airbag cut off? I assume no since they have a usable back seat
To keep the Passenger Airbag activated (without the PAD installed):
Install a 1000 ohm resistor between the WH/LB and BK/OG wires.
Connect a lamp (the one in the PAD) between the YE/LG and BK/LG wires so that your dash Airbag light will remain out following a successful self test, which occurs at Key On (verifying that the dash and PAD lamps are present and good).
So, for those few with the FULL Ranger FX4 center console with the subwoofer in it, how is the passenger airbag switch set up? I have seen pics of the console but none have been close enough to see how the airbag switch is set up
See last pic
http://www.therangerstation.com/resources/2009_Ranger.htm[/QUOTE
Bump. Just got a full console and wondering best way to deal with airbag switch to keep it working as is
