- Apr 13, 2008
- Fort Lauderdale
- State - Country
- FL - USA
- Other
- FLEX-fuel, baby!
- Drive
- 4WD
- 3.0 V6
- Total Lift
- 0" bone stock
- Tire Size
- P235/75R15
- My credo
- A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
RE: shims, spacers, crush-washers... I think I've got it covered... sent my trained rat into the rat's nest, and he came back with: Fel-Pro nylon Ford-V6-specific washer (Part #72515), about 0.085" thick, and from the M5OD maintenance episode, aluminum crush washers ~70 mils thick, and copper crushies ~40 mils thick... I just gotta "sack up" and go for it!
www.therangerstation.com
M5OD Aluminum crush washers for Fill & Drain plugs = NAPA replacement #704-1974
Does FoMoCo still support our fave reliable Mazda stick-shift tranny? And if so, at what price? No worries, NAPA Part # 704-1974 will do the job, cheaply, AND... Made In The USA! The NAPA version is both thicker and has larger O.D. (but same I.D.) as the OEM crush washers, but there are zero...
