Quick 3.0 Taurus swap question
oachs83
Minnesota
2002 Ranger has over 200k and I now have 0lbs in cylinder 2. I found a 2004 Taurus boneyard engine with 52k on it for $175. Other than needing to swap the head gaskets and upper intake and I'm sure front accesories what is a must need other swap parts. Like can I keep the taurus injectors and etc. Basically I want to keep as much stuff from a 52k motor rather than use a tired 200k part. Thanks in advance.
I had to also swap the water pump on mine, I have heard others who did not, You should be fine on the Injectors if both vehicles match as far as either being Flex fuel or Gas.
Do not re-use the head bolts as they are Torque to Yeild
JP02XLT
