sheltonfilms
Before you buy another alternator check your voltage regulator fuse! I had the same exact problem as described. Swapped like 3 alternators, still same results. So I went through my fuses (box under hood) and found that one wasn't seated right. It was the voltage regulator fuse. If its not the fuse check for bad wires on that same circuit. The regulators can be perfectly fine but if there is something wrong in that circuit it will still show bad.
