Everything back from the powder coatings place
TTB out
Oh wait... shit, it's going back in
Shiny new stuff bolted up
Instead of running the stiff springs that come with the James Duff kit along with the factory block, I used Trail Gear 3" yota springs. These will flex and ride much better while eliminating the factory block. I didn't go into detail on installation on my other truck, but it's simple. If you don't want to drill out your spring hangers and shackles for the larger bolt that the yota spring requires, you can do what I did here which I find to be much easier.
Pound the steel sleeve out of the stock ranger spring bushings
Grab a 13/16" drill bit and drill out the toyota spring bushings
Use a little lube and pound the ranger sleeve into the yota bushing with a dead blow
And that is it. Spring install is straight forward though you will have purchase shorter u-bolts because the stock ranger ones are not threaded far enough down once the block is removed.
So this is where I'm currently at. My front gears showed up yesterday, so I'm going to install those before throwing the front axle back in. I also pulled the trans back out, replaced the clutch again, resurfaced another flywheel and re-installed it all. Hopefully no clutch chatter this time, I think it was a weak pressure plate that caused it.
