Power Steering Pump
supergoalieman
10+ Year Member
I have a 1983 Ford Ranger which I am putting in a 351w in it. I read up online to use these three part numbers. I'm having trouble finding which models they actually came off of, if anyone knows that would be a great help.
Ford P/S Brackets P/N E7TZ-3C511-A
Ford P/S Pump P/N E6SZ-3A674-B
Ford P/S Reservoir P/N E1FZ-3A697-A
You will be able to utilize your stock power steering pump by using the correct brackets. These brackets can be found on
most Ford passenger cars from 1978-86
. In addition to this, you will need to obtain the correct V8 pulley for proper belt
alignment. The hoses can be retained in the original length on most conversions.
#E5AZ-3C511-A Ford P/S Brackets
#E6SZ-3A674-B Ford P/S Pump
#E1FZ-3A697-A Ford P/S Reservoir
Hope this helps
