power loss
jarfly
Got a 89 ranger 2.9/ aiu
to that is loosening power after it gets warmed up, you have to keep it full throttle to run 55, and wont rev past 3k
I can shut truck off and let set for a bit, it starts easy and will rev past 3K.
then will loose power after 10-15 minints of driving. Allso after it starts doing this, the gauges does not work right, they jump back forth.
Thanks in advance for the hep
Gauges jumping around are an electrical issue. I'd start by running a seconary ground cable betwee the engine and the body. I have used the stud off the top of the RF shock for this with some success. I wouldn't do it as a long term thing, but its ok with a quick and dirty test.
