- Aug 6, 2007
- Age
- 48
- Berrien Springs, MI
- Manual
- My credo
- If you can't go through it or around it, then go over it.
I need recommendations on a portable in residence gas heater. something that is efficient and does not require installation. this will be a back up for when the power goes out.
the area it has to heat is approx. 900sft. It will be going near a window that already has a brick hearth (like there used to be a gas fireplace there) so fresh air is not an issue. I would rather install a wood stove or a gas fire place but this is a rental so that is a no go.
