Got the rear end all primed and painted. I dont have any pics of it under the truck yet.
I put all new seals in it and filled it up with synthetic
I got the exhuast finished.
this is where I put the new flange on the cat so it doesnt reduce to 2.25
I started putting on the the front lift brackets, but I ran into some more fun stuff that halted that whole project. I found out that when the previous owner said the front end is pretty tight he must have meant it was tight .... last year. I ended up putting in 4 Moog ball joints in and 3 axle shaft Ujoints, and discovered that the RA bushings were junk, but the RA's don't bother me because I already got some new Moog bushings for when I finish my extended RA's.
I picked up a D 35 with 3.73's in it as well. It needs new seals but other than that it is ready to bolt on.(not sure if I mentioned before that the truck came with
3.27's in it
I was at the JY the other day and noticed that some older Exploders have a front sway bar that curves down about 2 inches on the ends. If I run it with my stock links I can run a sway bar with my lift. I will get a few pics tomorrow.
I am still waitng on my rear shocks and drive shaft so I can finish up the rear. I am going put the calipers on and make my new P brake cable brackets tom. I think I will need to find a way to extend my cable though.
