Seals finally showed up...damn USPS. They started in Cleveland, OH (3 hrs tops) and took 2 days to make it to Columbus, OH (Reasonable, I am basically in Columbus) then they sat there for 3 days before showing up in MI...then took another 3 to make it back to Columbus for delivery....meanwhile the tracking info said "Priority 2 day shipping...Status: On Time".lol
Not that I was really in a hurry, but every time I use USPS it is awful.
Anywho..I was able to actually find the old style seal with the flange that keeps the seal from going to too deep and keeps it straight.
Also bought a 1354 doubler from a member of another Ranger group (maybe on TRS too, IDK)..
It showed up Monday. It was a total pile off shit.
A. It was cut in the wrong location, so one key bolt hole was lost, and the sealing surface was reduced to a knife edge.
B. The holes in the plate were have ass measured and wallowed out to fit.
C. The "studs" were not straight and welded in with tack welds vs actually being drilled and tapped.
D. He used an electric case housing??? So no provisions for the shifter. He included some POS rod for shifting it manually through the breather hole. (No good way to seal, not detents to hold it in gear)
E. The shaft he supposedly bought (Duffy I thought I read, but the ad is now gone so I have no way double check what was said) is a damn welded together 2 piece...and it has a few micro cracks from improper cooling...
Some of this is my fault for no asking more questions or for more pictures. I assumed anyone brave enough to tackle a DIY doubler would have some better fabrication skills.
He is giving most of my money back, but I am out almost $100 for return shipping.
There is no wayyy this thing would have ever sealed up with the missing bolts, poor fitting block off plate, and horrible sealing surface on the cut portion.
Here is how mine is cut for reference. Notice I left both bolt holes intact.
With his half ass attempt, there is no bolts for a 10" stretch, where the mating surfaces are already not flat and have 1/32 to 1/16" gap when fully bolted together. That's relying a bit to much on sealer to hold up.
I was furious...I wish I could go back and read the ad again, but its gone. I can't see myself overlooking that many flaws. But maybe I just slipped up and got excited for a reasonably priced doubler and pulled the trigger early.
So looks like the B2 truggy project will remain single t case for a while longer
