As posted before, it is has about 2" of lift overall. Explorer leaves out back (2-3"), and about 1.5" of spacer in the front. Other than that it's all stock and I fit 33x12.5x15's on 15x8 with 3.75 backspacing wheels. I only had to do very minor fender/ bumper trimming, in the front only, the rear was just fine. The fender, I actually just used a sledge hammer and drove the fender opening at the bottom back a bit, it is all still hidden by the flare, so it looks stock from the side. Now they have no rubbing issues that I have found.
the suspension is a Dana 60 full float rear, Dana 44 HD front both housing 4.10 gears, total of 16 inches of lift including the body lift. The rear is factory springs out of a 1977 F250 high boy, the front is a 6 inch chevy spring 44 in eye to eye with a 7 inch perch, the tires ate 16 x 38.5 x 16.5 swampers. The truck can safely handle a 40 in tire with no rubbing
Blue one is a 1989 ford Bronco II 4wd, 33"x12.5" interco trxus M/T on a black steel rim. No fender trimming with a 6" BDS suspension lift. (No tire rub)
White one is a 1988 ford Bronco II 2wd, Back tires are P245/60/r15 on a aluminum panther rim, Fronts are a P205/60R15 on the same rim. Stock ride height.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
