Eddo Rogue
- May 18, 2020
- Burbank,CA
- 4.0 V6
- Total Lift
- skyjacker front leveling kit
- Tire Size
- 31-10.50R15
- My credo
- Crossed threads are tight threads.
Wasn't sure where to post this, because it involves steering, brakes, suspension etc...Although I don't help, just parts list suggestions. Lets assume its all trashed.
I am done messing around, and want to fix everything wrong with the front end, and maybe even some of the engineering flaws. Its gotten really bad. Like not sure where to start, just gonna do it all.
I am envisioning what I will need to replace starting with the middle and working my way out. There is some obvious stuff, but gets a little confusing towards the wheels where all the small parts go.
I've already replaced shocks/brakes.
anyways here is the sort of list so far....Lets throw some parts!
-Axle pivot bushings (polyurethane?)
-centerlink/drag link...new pitman arm?
-tie rods for sure
-ball joints
-wheel bearings
-reman or new steering box.
-+1 power steering pump.
Things I am not sure of:
-radius arm bushings? or should I get longer ones? I only have a leveling kit for lift.
-steering knuckle u joints?
- any bearings/seals besides just the inner and outer wheel bearings?
-any other steering parts I should replace?
-axle u joints?
-rebuild the hubs? Surprisingly they still work.
Is there anything I shouldn't or probably won't need to touch?
*I a plan to die grind the extra meat where steering binds in 4wd, anything else I should do while I have the welder and grinder out? Got plenty of flat bar and tubing to box in, gusset, reinforce etc...
This is a 90k original mile truck that is mostly babied and once in awhile abused. I just want it to steer and handle decent on the street (and trail).
Please do not suggest a SAS swap unless you have one to donate lol.
-tie rods for sure
-ball joints
-wheel bearings
-axle u joints?
