Part number on the A/C clutch relay?
aeidian
89 2.9 4x4 Ranger.
Bought it used, missing the relay for the a/c compressor. There's the Fuel Pump relay, ECC relay, and then what's supposed to be the A/C compressor clutch relay, I'm assuming. Jumping the connectors I can get the clutch to engage. I'm not sure what the relay's actual name or part number is, hoping someone does. It's a 5 slot plug, but only 4 wires going to it. I've read that you can switch in the horn relay, but I can't find a horn relay anywhere. When I asked the parts store they thought I was talking about the blower motor relay, then the a/c switch on what I would guess is the condenser, the thing with 2 plugs into the cylinder. It's neither of those. When he found an a/c relay the part number he told me is for a relay I already purchased for the fuel pump replacement, and it's a 5 prong one that does nothing when plugged in, I don't think that's the right relay.
A relay is a relay for the most part. Fuel pump and a/c should be the same standard relay. You may be able to jump the connector and make the compressor come on but for some reason the relay isn't being turned on. Probably a low charge in the system. There has to be power getting through the pressure switch to turn the relay on.
The AC relay is the same part number as the fuel pump relay. Napa #AR240.
