User Name missing
- Mar 16, 2009
I’m using a blue metal flake enamel paint in my testors/aztek external mix model air brush. I thinned the paint and played with psi settings from 10 psi up to 40 psi. At 40psi, I get better coverage but the paint still “spits” out. Nozzle isn’t clogged. Do I have the paint too thin/not thin enough or is something else wrong? Painting my daughters with just regular thinned enamel paint came out better, but some of the surfaces isn’t really glossy and has a kind of powdery finish. I plan on wet sanding both and shooting another coat of paint tonight.
The block of pinewood comes with slots precut for the axles. However the design req’d a different axle spacing, so I flipped it over and redrilled new holes using a jig. Is it ok like this or should I recut the slot? I’m afraid of the nail axle busting out the pinewood.
First time making one. Thanx for any help.
