2.5L ('98-'01) P0401 & P1401 insanity
riverside
CA - USA
Vehicle
Drive
2.5 (4 Cylinder)
Ive been researching here, other sites, chatgpt everything I can think of and i cant figure this out.
1999 Ranger 2.5L 126k miles , besides the check engine light i get this bogg of the engine when shifting into drive and starting off almost everytime. this is everything I did in order of circumstances to where I am now currently.
check engine light got a p0401 then proceeded to :
- new IAC valve - still same code
-new upstream o2 Sensor - nothing
-new DPFE sensor - nothing
- new EGR Valve - nothing
-new EGR pipe - nothing
- Hired a mechanic to come take apart and clean the enitre throttle body and intake manifold ( it wasn't clogged at all like ive seen in some cases ) - still got the same light 25 ish miles later after clearing code
- new evr solenoid - after this clearing of the check engine my p0401 went away and just got p1401 now.
- new hoses for the DPFE sensor ( theyre on the correct ports 100% sure ) - nothing
- bought a multimeter to check the wires that plug into the egr valve and they all checked out proper voltages aand after driving im getting both codes not stored after clearing them.
now this is where I am lost idk what else to do /try. I really appreciate some insight.
Have you modified the exhaust or gutted the cat?
Looks like your last code is about the DPFE sensor. I would be curious, when the truck is warmed up and idling, if you found a port somewhere with vacuum on it, if you hooked the EGR valve vacuum line directly to the manifold vacuum port, does the engine stall? It should. That would verify the EGR valve is working, the EGR pipes are not clogged.
If it did not stall, that does verify the problem, you are not getting EGR into the intake. You will have to keep trying to figure out why. The exhaust going into the engine at idle should make the engine stall out.
If it does stall, I would check the wiring to the DPFE sensor. I would then unplug the sensor, run the engine, see if you get a different code with the sensor unplugged.
Sorry for the late reply got busy.
So after talking to many mechanics and all my research I came to the conclusion it had to be the duralast dpfe sensor not working correctly because it wasn’t calibrated proper voltage so I bought the motorcraft sensor with the Motorola 1V and installed it and no light has come back. Will check back in after long get driving time but it seems to be fixed for now. I feel really dumb that’s all it was but c’est la vie. Thanks for your help again 🙌🏼
Update, lights back on with P0401 again yay.
I tried sucking through the hose that goes to the top of the egr valve , no engine stumble so I’m assuming it’s a clogged passage somewhere even after getting it all cleaned professionally. I remember reading theirs a really tiny hole somewhere that commonly gets over looked? Can anyone explain where that is exactly? From what I understand I can’t access just by removing the egr valve correct?
If you opened the valve all the way at idle, the engine should have stalled. If you want to try again, find a port that you can temp unplug that has engine vacuum on it all the time. Plug the egr into that and she should quit.
