BTlilred
Pressure build up and over heating, blows off the reservoir cap, no coolant in the oil, no oil in the coolant, has plenty of coolant in it, new radiator, new thermostat. Head gasket?
Perhaps the baby needs burping after the T-stat/ radiator work-I'd remove stat then run engine with rad cap off to look for bubbles.
A water pump is not a "real" pump, it is just a circulator, it adds no pressure.
It is not able to generate any real "pressure" it does generate "Flow"
Those test strips were available at Advanced auto & OrileysJP02XLT
There is less than 1 psi static pressure in and out total on the pump.
The pressure cap is release volume pressure as the coolant expands when it gets hot. When the pressure gets too high flow cfm stops.
