97ranger xlt
it will be interesting to see if the M1 cuts down on oil consumption for a high revving 4cyl with 222k on it...
no leaks sofar?
no leaks sofar?
no leaks sofar?
Has anyone ever used Mobil 1 High Mileage 10W40? Or Maybe Pennzoil Platinum? But they only make the platinum in 30 wt I wanted to try and slow down my oil consumption between oil changes, which is about a 1/2 qt to 1 qt every 4k...
The main reason I wouldn't switch to Syntetic is because it WILL start leaking. It it already leaks, it will get worse. edit: read you replaced all your seals, so this point may be moot.
I bought my Buick with 108k miles on it, and started running Royal Purple Synthetic in it immediately. It didn't leak a drop when I bought it, within a couple thousand miles it started leaving spots on the floor, it was leaking from the oil pan gasket and main seals.
As far as protecting better..it just spun a bearing at 142k. I'm gonna go the cheap route and just run convential in my replacement engine.
If you buy a car new, and run it on Synthetic from the start, its all good, but if its been running on conventional for hundreds of thousands of miles, don't bother switching.
Sure is a lot of BS going around here. If your engine doesn't leak now, synthetics will not make it leak.
A good synthetic is better in every way for engine life, than a conventional oil, which is why conventional oil is used to break in a new engine. It allows more engine wear.
You should also not be using 10W oil in your engine. 5W30 is probably what it was originally designed for, but even that is not sufficient, it also has other characteristics to be considered. The are designated by the additional ratings listed.
I use Rotella Synthetic 5W-40 in my BII, but not until I discovered that it is the only American oil that meets the standards for my BMW.
If it's good enough for the Bimmer, it's good enough for the BII (which has 325,000 miles, BTW).
So, if you want better mileage, use a full synthetic 5W-30 or 5W-40. Your engine will last longer, and you'll save some money on gas.
I owned my Buick for 3 months before I switched to synthetic. It didn't leak a DROP, I was underneath it a few times, and it was completely dry. 1 month after switching to Royal purple I noticed oil started running down the oil pan all the way around, and it started dripping shortly after I noticed. Tell me, since you're the expert, how did this happen? Did the oil pan gasket and main seals just happen to go bad completely by coincidence?
Ya, exbass said if it already leaks putting in synthetic could make it worse...thats pretty much the same deal as "making it leak", because it made it worse 10 fold.
Update. I am coming on 2K miles. No real change in fuel mileage. I have noticed though on start up, instead of my oil light coming on for a second or so, it flickers very fast for no more than a second, and goes off. Will let ya'll know about oil consumption and oil samples. It would be really help full if someone knew how to convert a pdf to a jpg to post my oil samples.
