Oil Filter Upgrade
PlumCrazy
OTOTM Winner
Solid Axle Swap
RBV's on Boost
2014 Truck of The Year
Millersport, OH
I was changing my oil today and got to thinking about how my dad used to use an extra long filter on our Chevy 350 so it would hold an extra quart. My rear main has a little bit of leak (1/2 quart every 2000 miles), so I was thinking it wouldnt hurt to have the extra oil capacity.
I got out my NAPA filter book and looked up the stock Ranger filter (4.0 and 2.0/2.3/2.5 use the same filter as the 7.5, 5.4 and many other Ford motors)
The stock Ranger filter is a 1515 (Napa #) and it is 3.6" around and 5.35" long with 3/4-16 threads. The O ring is inboard and has a 2.834 ID.
I ended up finding a filter with the same thread, diameter,and O ring, but its 6.982" long. The NAPA # is 1773. (the Purolater was L400017) I also found a 1333 is a little bigger around (3.7") and 6.982" long, but it is valved different it was 30psi where as the 1773 and 1515 are 8-10 psi.
The stock filter holds around .625 t.750 of a qt. The 1773 holds 1.25-1.50 qts. So in the end you end up with 1/2 qt more capacity. This filter would work on the 2.0/2.3/2.5 but you would have to put a 90* adapter in because it would be too long to fit in there.
Here are a few pics. It is still tucked up high enough to be protected.
as long as the filter doesn't become a rock catcher, and by
your PIC doesn't appear to be at hazard....
BTW, love your homebrew extended radius arms.
AD
AD
The filter is completly out of harms way. Its higher then the oil pan, and the radius arm will block anything coming off the tire.
I am thinking of getting some square tube adapters and run some ballistic joints.
I was thinking about putting an amsoil oil bypass style filter on my ranger like what I had on my diesel..... 2extra quarts capacity and better filtering.
Frank
