Not trying to hijack a thread, I have a 94 Ranger 4x4 with the 4.0l ohv w/ 302,000. I getting a little nervous and would like to install a 4.0 sohc. Since my ranger is a little older than his 97' and runs obd I, what would i need differntly to do the conversion??
Thanks,
Jim
damn 302,000 miles!!
Anybody??
Won't be as easy as the OP. AC box in the engine compartment will have to go, custom engine harness will have to be made, you'll have to find a tuner that can actually reprogram the ODB-1 to work - several other misc. things to do or have done - in other words, a real PITA.
Bird
I don't know that much about obd systems, Could i just switch out computers?
My '02 has the timing chain problem, like many others out there.what kind of issues, anything i should be worried about??
how much work do you guys think it would be to put a sohc 4.0L in my 03 Edge i got the 3L 5spd i know i need a different tranny but would it be any kind of direct swap?
Um, basically my question is since Im putting an explorer engine into a ranger, where should I get the wiring harness/ecu out of? A 4.0 ragner or explorer? Anyone? thanks.
The Ranger did not come with the 4.0 SOHC engine until 2001. Your friends 2000 with the timing chain noise has nothing to do with the 4.0 SOHC timing chain problem.I have also heard intially the chain tensioners were a bad design, I think it took until about 2001 to fix it, i have a friend with a 2000 ranger and i can hear the timing chain when it idles. Not a good thing, it only has 125,000 Miles.
The explorer.
