Oh NO!!... NOT the dreaded timing chain cover COOLANT LEAK! =:O
... I now see clearly why there's 3 gaskets and a crank seal. (y)
But what I DON'T see in those pics are the special oil-pan related gaskets mentioned earlier in this thread...?
If you think this job is “fun” with a ranger chassis, try it in a ‘93 taurus fwd with the motor sideways! Its been years ago but I do remember it, was a pain!
Yep, I had a same-era Taurus with the same 3.0, and while I never had to do anything major to the engine, I do remember having to remove the right-front wheel (and splash skirt) for just about anything, even a fan-belt swap, IIRC... never liked FWD... but I wouldn't turn down a minty rust-free Taurus SHO w/ manual, lol...
FWIW I wouldn't be too afraid of that job if you're decent with a wrench. There are a couple good threads on here with advice and I posted a few things I noticed doing mine, including how I dealt with pitting on the timing cover housing.
It's been a few years now but I don't recall any major gotchas. As I recall, getting off the fan clutch was the biggest pain and that was solved with the proper tools. There's nothing really tricky about the job especially if you're not in a big hurry. I would suggest just doing the timing chain while you're in there depending on your mileage and what you find - if you do that you shouldn't need to go in there again for the life of the vehicle.
I'm about to go out and patch it with Permatex Form-a-Gasket #1, for the short term... my observation is it's a temperature-triggered leak: doesn't leak when it's cold, or even the moment the thermostat opens, but only once that end of the block and timing cover get up to "steady state" hot. And "end o' the day" we're only holding back 15 PSI... not asking it to seal Power Steering or Braking pressures... :oops:
I may have long-term use of a garage (and a beater-loaner car) in a couple months... there's NO WAY I personally am getting this done in one day, not even counting other issues I'll probably discover during disassembly... probably do the rest of my brake lines and drum brake "refresh" while I'm at it. NOT being out in the sun and rain all day will take some getting used to, but I'll adapt! :giggle:
Thanks again for all the advice, and KEEP IT COMING!
ALLL-righty then, that went smoother than I expected, and the predicted 4PM rain held off too... put on the gloves (and safety gogs) and got under there, BRAKE CLEANER in hand, noticed a bit of coolant weep even though truck hasn't run for 2 days... my spot is only shady in the morning, figured it built up a bit of pressure from sitting in the sun, so popped the rad-cap and sure enough, a small spurt, but not enough to push the plunger and go to the overflow reservoir... got back under, hosed it down REAL good with (Greta Thunberg-approved NON-chlorinated :rolleyes:) brake cleaner, until I was looking at nekkid cast iron, and I guess aluminum for the Timing Cover...?
Anyhoo, put a nice bead of the reddish-brown goo way past the dye stain in each direction, tried pushing it into the junction... and now I just wait. Starting a new job tomorrow, gotta roll at 7:30AM, but it's only 3.4 miles away, could probably make it with zero coolant... KIDDING! Leak is not THAT bad, and if this even slows it down it'll be win. Dollar Tree helping out with Prestone 50/50 for only $5/gallon! Took me 7 months to go through the previous gallon, new larger leak probably 1-2 months, depending on miles. (But it's embarrassing visiting friends, and having to borrow the garden hose on your way out, lol...)
NB: in another thread on this same topic, someone mentioned the frame being in the way from below, but on my setup (4WD w/ Torsion Bars), it seems that if I simply removed my beefy 29mm sway-bar (time for new bushings anyway), I'd have quite a nice "corridor" to work in... might have to remove only the fan shroud, but not the radiator...?
Or do I want to remove not only the rad, but the grille too, so I can basically "walk" the new timing cover "straight-in", with great visibility and access from all angles?? :icon_confused:
