Oh NO!!... NOT the dreaded timing chain cover COOLANT LEAK! =:O
fixizin
FoMoCo is forcing me to buy a 'yota
⭐Supporting Member
Fort Lauderdale
FL - USA
Other
FLEX-fuel, baby!
Drive
0" bone stock
P235/75R15
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
DAY-um, put some AC Delco tracer-dye in the radiator, and looks like the upper passenger-side corner of ye old TC cover is NOT mated to the block as it's supposed to be... durn.
And what's with that "wandering" gasket I circled in red??????
(Big orange "Romex" is for the engine block heater... yeah, not a thing in Florida...)
I saw somewhere in passing (prob. not on TRS), that there was some Permatex product you could smear on there to buy some time????
Just wait till you go to do this job and repair it, and try to get some of the bolts out. Fun fun.
I
I've followed the tribulations of my fellow 3.slowers for years on this issue... it's a VERY INVOLVED repair... Lordy!
... I may have to punt this job... any idea on the "book hours" on it??? :eek:
Oh yeah... fun. I can't imagine it's any worse than doing it on a 4.0 (which I have done several) and those are probably a 6-8 hour job. It's not THAT bad... getting everything torqued in the right order and the timing cover aligned to the balancer is the main thing.
If you can get an OEM timing cover gasket, you'll thank yourself. I don't have a part number handy, I can just tell you from experience that those gray paper Felpro gaskets are pieces of crap and the OEM ones are substantially better quality.
For YOU it's 1 business day... for moi, I can see it easily going 3 days... :icon_twisted: ... unless I had the "powerplant" out of the truck on an engine stand.
What about the OIL PAN interface/interference??? :eek:
Oh, I thought Fel-Pro was BETTER than OEM?... anyway, on the one hand my OEM gasket lasted almost 27 years... OTOH I just hit a mere 90,000 miles in August so...??
ALSO, look at the section of gasket I circled in RED above... WTHey is up with that?
Oil pan/block/timing cover needs a little bit of RTV in the sharp corners. I usually pull the timing cover pretty close to the block first, then snug up the pan bolts, then snug up the block bolts.
Not sure what’s up with the thing you circled, looks like a gasket that blew out but it should be leaking a lot more of that was the case.
