OdinAF
So you have to fill your differentials or drain them. Well here is a simple trick that most know, but a ton don't, before draining drive you car to warm the oil up and like the spice, it must flowww.
Now say you have to fill, I know I know, Your not sure how to heat the liquid, the same way I don't know how to make complete and proper sentences.
Behold the glory of man.....
Take a simple heater pad and wrap it around your bottle let it sit for 20- 30 mins and vola.... the oil will flow.
Also you could use a pump, but I'm a Engineer so I will be damned if we do this the easy way.
