No switched power to stereo
Featured Build Threads
Firestar
Latrobe, California
God first
Trying to install new Sony stereo in my 94 Ranger. I have no power on the switched power lead, in ACC or in the ON position. Fuse #11 is OK. Also have conflicting info on which fuse controls the radio/stereo. It's kinda hard to check but I don't see 12 volts getting to the the fuse block under the dash on fuse #11. Where does the power come from? None of the wiring diagrams I've found have this info. It had an after-market stereo in it when I got it and it didn't work in the ACC position.
Thanks for the reply, WarHawk, however, I've looked at both of the diagrams that you directed me to and neither of them answer the question of where the power comes from. As mentioned, I don't believe I have ACC power getting to the fuse block, and I can't figure out how that ACC power gets to the fuse block. Also, is there any other fuses or accessories that would be affected if there's no ACC power at all.
Event Coverage
Featured Ranger Based Vehicle
