cp2295
- Jul 25, 2013
- Washougal, wa
- My credo
- If you ain't first you're last
Got a 99 with a swapped in 4.0 with a 98 PCM. Worked fine the 7 months I've had it but I was driving today and all of a sudden it shut off. I have no spark and the fuel pump doesn't make the whirring noise when you put the truck Into the on position. I also don't have the cel flashing like it usually does when you turn to the on. I cannot connect my scanner to the truck either. All she does is crank but no start.
What would cause this is my PCM fried?
