Hi,
I’ve got a 1988 bronco ii. Last year, on a hot day it stalled driving about 40 down the road. I replaced the tfi module. Then it started stalling and not starting for a few minutes. I checked the inertia switch. The connection was melted, so I figured I’d replace that. It drove fine the short distance I drove it. Then it started dropping rpms after it is was warmed up. I couldn’t give it gas to accelerate and the transmission sort of felt like the clutch was slipping and the stick was wobbling. It seemed like it was probably fuel so I checked the fuel pump relay. The plastic case was broken with a piece of electrical tape on it and the contacts in the wire harness were corroded. I figured that was a good place to start. Again. It drove fine until it was warmed up and I let it idle for five minutes at a gas station and it did it again. It also idles really low 5-600 rpms when this problem occurs. Engine thermostat is set for 180 degrees and stays there when warmed up, but I do smell a burning smell when this problem occurs (not of gasoline) sorry for a rambling post. Any ideas? Thank you for your help.
