No power to fuel pump on 4.0 ohv
Alright guys so I found the problem. My supply line for fuel is plugged into my return line and my return line is plugged into my supply line. Now I'm not out of the woods yet because the fittings are swapped. I removed the supply line fitting and tried screwing it in the back of the fuel rail and it's too big a fitting and vice versa for the return line. Now because I modified my lines, I took a 4.0 line from a junkyard and cut the male connector off behind the braided line for the return line. I used the same line from the 2.9 to supply fuel because the male connector plugs right in. Any ideas how to get the fittings swapped?? I'm at a loss for ideas
Sent from my SAMSUNG-SGH-I537 using Tapatalk
