Uly The Hermit
- Apr 18, 2009
- Automatic
Hi. The O/D quit working on my '91 Explorer, 4.0L, auto A4LD trans, 4WD. It will not engage at all--just like putting it in neutral. From everything I've read so far it sounds like the O/D sprag broke. Not sure what that is but is it OK to continue to drive it in D? Or is it likely that it will suddenly fail and not go at all? It seems to work OK in R, D, 1, and 2.
The trans is supposedly a rebuilt that has maybe 40K miles on it since installed. The fluid was changed about 20K miles ago when it had a shift lever seal leak and then again about 1000 miles ago when it looked like it needed to be changed. New filter/gasket both times too.
