mightysonofa
AFTER I DID THE DURA SPARK SWAP I HAVE NO KEY ON LIGHTS IN THE DASH CLUSTER. IS THIS NORMAL ?I REMOVED THE HARNESS AND THE COMPUTER AND CUT THE WIRES FROM THE SQUARE PLUG TO THE HARNESS THAT WENT INTO THE COMPUTER HARNESS BUT LEFT THE SENSOR WIRES FOR THE TEMP, HOT FOR COIL,HOT FOR ELETRONIC CHOKE,AND THE 2 WIRES FOR THE ALTERNATOR .DID I CUT OFF MORE THEN I SHOULD HAVE ? HAS ANY ONE HAD THIS PROBLEM TOO?
