- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
I got the timing components reinstalled on my project yesterday. Borrowed the battery from my F-100 to test it out. 1985 Ranger 2.3L A4LD 2wd. Just a reminder, there was no before to compare it to, I bought it with the engine in pieces.
Transmission in Park, foot on brake (shouldn't matter), turn key, nothing. Well I can't say nothing. With the switch in run everything seems to work, so getting power into the cab and ignition switch. I'm pretty certain that I heard the fuel pump running, but I don't think there's any gas in it at the moment. When I turn the key on over to start, the engine doesn't crank. I can jump the start post on the solenoid and it spins right over, coil disconnected of course. Won't turn over with the key.
Now when I turn ket to run I don't get any KOEO warning lamps on the dash (IE: brake, CEL), but I don't remember if these do that. When I turn the key over to start, the parking brake light does illuminate. But since I have power coming into the cab and acessories work with in the run position, I'm thinking the ignition switch is probably ok.
Only other thing I can come up with between the ignition switch and the starter solenoid is the neutral safety switch. Costs around $60, and I don't exactly fit under the truck to replace it. Truck is parked out in the yard, no safe way to get it in the air at the moment. Before I spend the money on a switch and go through the effort of getting the thing on stands, is there anying else I should check that could be causing this? Anything easier to check than getting it up on stands on an unstable surface?
