bcraig
Hi,I amnew here and need help.
I have owned a Ranger 1996 with the 4 cyl and manual trans for years ,I neede a4x4 foruse one farm and as a genera lpurpose vehicle I bought a used one yesterday and not knowing what to look for got into some problems I dont know how to remedy.
This is going to be long and as detailed as I can make it in an effort to get the best help I can.
When i was looking at the truck(1996 Ranger with 4 liter and auto transmission)I asked the guy who owned the truck how to put it in 4wd,he told me to put in Neutral and turn the switch to where i wanted it( 4high 4 low etc)I did soand heard a little bit of a clunking noise and it felt like it had gone into a lower type of drivemode(ratio),I bought the truck and took it home.Now i find that when i got home (in the country)that justthe rear wheels were spinning ,no clunk going into low 4wd but dash light was on. I could hear and feel something best descried as a grinding ,clinking when switch was in 4low according to dash light but could not see front tires spinning in wet grass of pasture(wife was helping me look as well)
Then pulled up to very small incline and had her watch the front wheels for pulling and she tells me not only are the front wheels not spinning but the drivers side rear is not spinning either.the only wheel turning was the passenger side rear.
Now iamreally confused ,i pulled it onto an asphalt part of drive with just the so called switch in 2 wd and gave it the gas and left ruber marks with both the drivers and passenger side rear tires!I am not a mechanic sodont understand how only one rear wheel(passenger rear would turn in wet grass on an incline when in so called low 4wd but then leave marks on the asphalt when in 2 high?
Some more information i can provide is that the shifting of the transmission is confusing. When itest drove the vehicle it seemed to shift ok but now seems to be shifting at different times now and seems like when going from1st to 2nd especially that it lingers in first and then goes to second,lingers so much that it seems like it has 5 shifts(including the overdrive.
Lastly the key in the ignition does not seem to turn backwards far enough and in fact I can take the key out and still start the vehicle!
I am obviously not a mechanic of any sort but am going to have to learn how to work on this as I cant afford to pay a mechanic to work on it.(retired on small fixed income)
I tried to write down everything I could so someone with that knowledge could figure out if all of it was connected.
I have 2 jackstands,basic 1/2 inch ratchets and sockets up to an inch,a small compressor and a vice and Pneumatic jack,grinder,vice grips etc to work with.
I would really appreciate some help here .
Thanks
And God Bless
Craig
Thanks
And God Bless
Craig
