new member needs advice
Jeff Hambone
Just purchased 1999 mazda B2500.check engine lite on. Code PO122
which says throttle pedal position sensor A circuit low input . What should I do to correct this?
4 cylinder engine .Also when shifting engine revs to 3500 rpm. I've replaced throttle position sensor, mass air , oxygen, intake air , and throttle body .( no change) .Still vevs 3500 rpm also while at steady speed feels like motor is surging. Thanks
Frankly,pay for diag and fix it yourself! GOOD DIAG may cost $100-$150 ,throwing parts at truck is not helping and adds to cost and frustration level
ur problem is u are not recieving enough voltage either to the tps or to the computer my advice is either take it some1 or get a multimeter or a test light and follow the wires and checking the wires for bad connections or breaks, since u said u already replaced the tps, i would start right there with boot that connects to the sensor istself, its in a high heat environment and somewhat exposed to the elimates
