Need vacuum info for throttle body, '93, 4.0
plobo
Appreciate if someone with a 93 4.0L could tell me (or snap a few pics) about the vacuum line running off the bottom of the throttle body - where does it go, what does it look like - bends, connectors, etc). I bought a run down ranger and rebuilt the engine top, did label vacuum lines off the manifold Tee but don't seem to have this line - could have been off the truck before I began but probably i lost it at some point.
thanks
josh
That line goes from the bottom of the TB, back toward the firewall and around the backside if the AC compressor then up to the charcoal canister behind the drivers side headlight.
Thanks that helped. I traced the line from firewall / AC and went to canister, found hose tucked away which was right shape/bends and size for TB.
