2.3L ('83-'97) Need Upper Passenger Side Motor Mount For 94 2300 Manual transmission Transmission
the steel bracket that bolts to the engine, or the rubber mount? For the bracket I think you would have to go look at a junkyard, for the rubber mount they should be available, they're all solid rubber instead of hydraulic like they were from the factory. I don't think they engine side brackets are very year specific, they switched to that style engine mount in 1987 and I'm pretty sure it was used through at least '97 if not til mid '01 when the Lima was no more...
The metal bracket between the top of the rubber mount and the engine block. I posted on Carparts.Com and got basic spam replies. I'll check again Friday. Thanks for the info. Worst case scenario I'll take the pieces into one of our better welding shops and see if they can do anything with it.
That should be a common part, but I've never heard of one breaking before... like i said I think that part is the same from '87 through at least '97, I THINK I have one for a '88 on a spare engine, I'll look tomorrow...
